csbmr
Sep 22, 2021Aspirant
Netgear 2400 usb control center - readyshare has to be reinstalled almost daily
- Sep 23, 2021
Anyway, I am now updated. Will let you know how it goes.
Thanks again.
csbmr
Sep 23, 2021Aspirant
Very confusing. I see a file to download for version 1.0.1.74 on the netgear website but even signing in from the web directly to the router, skipping Genie, going to the advanced tab and checking for updates; it says there that there are no further updates available. What is up with that? Is 1.0.1.74 a real release or something just released and maybe not fully tested? Why doesn't the router software find that release? When was this relesed? Have you been using this a while?
csbmr
Thanks again.
- michaelkenwardSep 24, 2021Guru - Experienced User
This might be useful for future reference:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Apps and built-in checks are there to make things look easy. In reality they are so dumbed down that they are more trouble than they are worth.
- csbmrOct 06, 2021Aspirant
After updating the router several days ago, I have not had a problem with having to reload the USB files. The update evidently fixed the issue. Not sure why automatic updates are not working and had to update manually, but it is working.
