pw2's avatar
pw2
NETGEAR 4300 (Possible Firmware Bug) V1.0.2.104
I updated my NETGEAR 4300 to firmware: V1.0.2.104   It seemed to then have unreliable wifi connections   I noticed this while using Facebook.com and very noticibly when I tried downloading a ...
  • pw2's avatar
    pw2
    Dec 03, 2018
    It looks like there is no problem and my initial request may be disregarded. Thanks for looking into it.
    After reverting back to V1.0.2.98 for a week, I retried V1.0.2.104 without resetting anything.  All settings successfully moved forward. It worked good this time and there was no further issue with downloading a 2GB file via WIFI.  The problem I noticed above may be related to an ISP issue as a neighbor in the building finally was able to get the ISP to do a DSLAM reset. The reported issue may have been just bad luck in timing, though reverting back to V1.0.2.98 at that exact time did seem to help.
    I do appreciate that they are still providing updates for this model (I have another on the shelf in shrink-wrap that I'll probably pull out when needed, so I'll probably get another 5 to 8 years from these two machines -- I hope they keep the updates coming!)
    Thanks again for your help and I'll remember your recommendation of resetting the settings if I need to do troubleshooting in the future.
