donniep
Oct 12, 2016Aspirant
Netgear 6250 5G not being displayed on HP laptop
I have been using the 5G on all my devices, Iphones, Ipads, MACs, Lenovo X86 laptop and a much older Toshiba Win7 laptop. However, my 1 year old HP Windows 10 laptop has never been able to locate t...
- Oct 13, 2016
If this is built into the laptop, then you are stuffed. Laptops are not amenable to replacing bits and pieces.
If 5G is essential to you, then a USB "dongle" is your best bet. Then disable the on-board wifi and use the dongle.
But is 5G really that important? Do you sit there wondering why things are so slow? Or is it just a nuisance that you can't get the best speed out of the R6250?
donniep
Oct 13, 2016Aspirant
Looks like the WLAN Card Ralink RT3290 only supports 2.4Ghz and not 5G. Any suggestions for upgrading the card? Thanks for the responses! Much appreciated!
michaelkenward
Oct 13, 2016Guru - Experienced User
- donniepOct 13, 2016Aspirant
Mostly a nuisance I guess, also annoyed that this newer laptop doesn't support something my 6 year old Toshiba laptop did. I do sit and wonder why this laprtop is so much slower. I'll check out the USB option and see if its worth it. Thanks again for the help!
