billu
Jul 19, 2022Tutor
Netgear 6300 - No WiFi Connections
Last night, my gateway stopped connecting wireless devices. I have rebooted the device several times. The gateway runs into a switch and the devices that are hardlined are functioning properly. I ...
Jul 19, 2022Guru - Experienced User
What actual router do you have? There's a c6300, R6300, D6300
What firmware is on it?
So none of the wireless devices are picking up a signal?
What are the led's showing for wifi?
did you try hitting the wifi on/off button and holding for 2 seconds?
What does it show if you log in through the browser for wifi broadcast?
Did you try a reboot?
A factory reset?
