billu
Jul 19, 2022Tutor
Netgear 6300 - No WiFi Connections
Last night, my gateway stopped connecting wireless devices. I have rebooted the device several times. The gateway runs into a switch and the devices that are hardlined are functioning properly. I ...
billu
Jul 19, 2022Tutor
Its a c6300v2
Firmware version is 1.03.04
Not a single wireless device is connecting.
LEDs are all green
I have not held the wifi button down.
Logging into the router, everything looks great. Says its broadcasting the SSID like it has for the past two years.
Several reboots
No factory reset (yet)
Jul 19, 2022Guru - Experienced User
I would try turning the wifi on/off and see if that helps.
If not, I'd try the factory reset.
- billuJul 19, 2022Tutor
YEs, I am going to rename the wireless and do a few other miscellaneous tests. I was hoping to avoid the factory reset because I run a full blown network at home with multiple servers. The wifi is primarily used for smart switches, and my iPad. But if I have to, I guess I will.
