warefamily359
Nov 03, 2020Aspirant
netgear 6300v2
I have a seagate 4 TB backup hard drive that it will not show on the Netgear c6300. Thank you for any walkthroughs. Appreciate it.
warefamily359
Nov 04, 2020Aspirant
Thank you I do not like to make overtly hasty generalizations as that is what people gravitate to and miss the overall issue. Other helpful users pointed to the same things you mentioned and this wherebI was a week ago. Two weeks ago I was in my manual scrutinizing it for solutions. Looks like there is a conflict between what seagates will work with the c6300 series and which will not. Seems like an issue for R and D to fix in the future. Thank you for being a decent person.
antinode
Nov 04, 2020Guru
> [...] Two weeks ago I was in my manual scrutinizing it for solutions.
_Which_ "my manual"? Did you get so far as the User Manual sections
recommended above?
> [...] What's the file system on your (unspecified) "a seagate 4 TB
> backup hard drive"?
Still a mystery.
> [...] Looks like [...]
Not really. But the only person here with a possibility of
investigating what might be the actual cause seems uninterested in doing
so (or unable to do so).
> [...] Seems like an issue for R and D to fix in the future. [...]
I wouldn't expect much serious activity until you provide some basic
information.
> [...] Thank you for being a decent person.
He's good at that, just as he's also good at repeating previous
suggestions (including "check the documentation").
Sadly, saying only that you were "in [your] manual scrutinizing it for
solutions" conveys no useful information about what you actually did, or
what happened when you did it. See "not a useful problem description
[...]", above. Nor does it answer the one critical question which has
been asked repeatedly to no effect. Without your help, the non-psychics
in your audience are left to guess, and I've grown tired of wasting my
time on what appears to be a hopeless project.
