Rc1962
Feb 09, 2022Follower
Netgear 65. Change name
Feb 09, 2022Guru - Experienced User
What router do you have?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
