donweston
May 17, 2021Follower
Netgear 71 router. Is the device password on the label unique to each router?
Is the password on the bottom of the router unique to each device? For clarity I am not referring to the ADMIN pasword. The password is located on the bottom of the router below the SSID #.
1 Reply
> on the bottom of the router below the SSID #.Do you mean the one labeled "Network Key (Password)"? I've never
seen the same one twice. But why trust me? Here's a radical, but
occasionally useful concept:https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Types of Logins" and "unique". Further reading might not hurt, either.If you're worried about it, then you should be able to change it.
That's also covered in the User Manual.
> Netgear 71 router. [...]
"NETGEAR71"?
When you buy parts for your car, do you give the person behind the
counter your license-plate number, or the make+model+year of the car?> [...] the ADMIN pasword. [...]
"admin"? Case is significant there, too.
