GXRM724's avatar
GXRM724
NETGEAR AC 1200 MODEL 6120 - When connected to router internet speed drops TO 100 Mbps FROM 200
NETGEAR AC 1200 MODEL 6120 When computer connected directly to modem internet speed is greater than 200 Mbps. When connected to router (NETGEAR AC 1200 MODEL 6120) internet speed drops TO less than ...
  • plemans's avatar
    May 06, 2022
    microchip8 is exactly correct. You bought a router that isn't gigabit capable.
    Its fast ethernet only meaning its connections are 10/100mbps.
    You'd need to upgrade to a gigabit router to utilize your speeds.
    Or downgrade your speeds and stick with 100mbps.
