mbolena
Feb 13, 2021Follower
Netgear AC 1750 dual band wifi mesh extender will not recognize Viasat router
Hi everyone, I had a bad reciever replaced on my Viasat dish today and a new modem along with it. My Netgear extender has worked fine for 6 months, after the maintenence work today it's no good. I do...
Feb 14, 2021Guru - Experienced User
what model number is the new router?
When you're installing the extender, are you using wps or using the installation assistant?
Try using the installation assistant.
