boggym
Oct 18, 2018Guide
Netgear AC 1750 Model R6400 i limiting my bandwidth
My ISP is giving me 150Mbps (I checked it dirrectly from the modem), and from the router I get maximum 105Mbps. Is there anything I could do to remove this limitation?
Thank you
- Oct 22, 2018
In the end it was the cable connecting my PC to the router that was only CAT5, wherefrom the limitation.
I changed it to CAT6, and right now I have 150Mbps.
boggym
Oct 18, 2018Guide
On wireless I have 149Mbps, and on wired I have mostly 105Mbps, so I do not quite get it.
I also changed the cables. When I was on 75Mbps it showed always a little bit over 75Mbps, however right now it is like throttled on 105Mbps.
TaterSalid
Oct 18, 2018Virtuoso
If you are in warranty they may talk to you free even beyond 90 days. They didn’t have a prepaired strategy for this issue. After 30 minutes he finally understood that I had a throughput issue. He told me to return the router to the retailer. They wouldn’t refund or exchange at 95 days so I will be calling support again. Good luck.
- boggymOct 18, 2018Guide
So you say that I should call the customer service?
I thought that I could find out a solution before going to talk to them.
Thank you
- TaterSalidOct 18, 2018VirtuosoMaybe. My thread is down about 15. So far the only reply is mine and that was an update. Apparently, this is not a common problem.
Thank you very much.
I think I will give it a try.
