kayayche
Dec 15, 2020Follower
Netgear AC1200 A6210 adapter constantly dropping connection
Every 1-2 hours, my adapter drops connection to the internet. No other solution or troubleshooting step I've been able to find in the support section, or here on the forums, or elsewhere has bee...
Reddog4613
Dec 16, 2020Aspirant
I'm having the same issue with my AC1900, Model R6900P. Sometimes the connection stays for a long time, sometimes it drops it every few minutes! Very frustrating. It use to keep connections with no issues.
I've been looking for solutions as well. I did the firmware check and it said it was up-to-date as well. BUT looking at the Downloads page, I saw a different version than what my router is reporting. I had v1.3.1.64_10.1.36 but the latest is 1.3.2.126_10.1.66 !! So I downloaded that firmware and installed it manually. I also turned off the "firmware auto update" feature.
I hope this firmware fixes the issue. Other solutions I've seen was to go back to an older firmware version. But I don't know where to find one and tell whether it is stable enough to use.
Good Luck.
