K4led
Jun 27, 2020Aspirant
Netgear AC1200 Can't reach certain web sites.
Can't reach certain web sites - other web sites OK. Power cycled modem and router. Reset router. I can get to the web site by connecting computer direct to cable modem but not through the router on a...
- Jun 27, 2020
I have fixed the problem by changing the router Basic>Internet>Use default MAC to Basic>Internet>Use Computer MAC. Now I can access the web site that woas previously not opening up. This is esentially the same as connecting the computer directly to the modem.
Jun 27, 2020Guru - Experienced User
What modem are you using?
Firmware on the router?
- K4ledJun 27, 2020Aspirant
Cable Modem is ARRIS CM3200
Netgear Firmware is V1.1.0.86_1.0.1
- plemansJun 27, 2020Guru - Experienced User
Have you tried using a different dns provider? Like googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1?
Also, check your pc/device for any services that can block sites like anti-virus/firewalls.
