K4led
Jun 27, 2020Aspirant
Netgear AC1200 Can't reach certain web sites.
Can't reach certain web sites - other web sites OK. Power cycled modem and router. Reset router. I can get to the web site by connecting computer direct to cable modem but not through the router on a...
- Jun 27, 2020
I have fixed the problem by changing the router Basic>Internet>Use default MAC to Basic>Internet>Use Computer MAC. Now I can access the web site that woas previously not opening up. This is esentially the same as connecting the computer directly to the modem.
K4led
Cable Modem is ARRIS CM3200
Netgear Firmware is V1.1.0.86_1.0.1
Jun 27, 2020Guru - Experienced User
Have you tried using a different dns provider? Like googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1?
Also, check your pc/device for any services that can block sites like anti-virus/firewalls.
- K4ledJun 27, 2020Aspirant
