Sofina
Jun 23, 2022Follower
Netgear AC1200 router power green blinking
Hello all, Why I realise the problem at first was my discord channel suddenly showed "no route", so I went to check my AC1200 router and found out that the power light is blinking green. I tried ...
michaelkenward
Jun 24, 2022Guru - Experienced User
What model is this router? AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
I also tried the TFTP method, so I followed the step from here: https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-on-Microsoft-Windows
TFTP is not an easy process to get right. You may have to try it several times.
This video might be useful.
