videohead-311
Dec 23, 2020Initiate
Netgear AC1200 Router will not work after firmware upgrade
The only light on it is the usb light. I tried tfpt2 and it starts and gets to about 70% then stops. I also tried tftpd64 it says #0 block and does nothing else.
Dec 23, 2020Guru - Experienced User
Lots of things can go wrong using tftp.
also, are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- videohead-311Dec 23, 2020Initiate
I think I finally have it back now. I did it through command prompt. It worked. Thanks!
