mdrfrisco
Aug 01, 2022Follower
Netgear AC1600
My new router is not connecting to my Samsung TV. I've tried to enter the network automatically & manually, won't connect.
Aug 02, 2022Guru - Experienced User
Details are key.
1. what actual router do you have? AC1600 is a speed, not a model
2. what modem/gateway is it connected to?
3. Is it only the tv with issue?
4. what error does the tv give you?
5. if you have any special characters or spaces in the ssid/password, remove them. Some of the more basic devices struggle with spaces/special characters.
