mdrfrisco
Aug 01, 2022Follower
Netgear AC1600
My new router is not connecting to my Samsung TV. I've tried to enter the network automatically & manually, won't connect.
michaelkenward
Aug 03, 2022Guru - Experienced User
Wrong way round.
It is important to approach this from the fight direction. Routers don't connect to TVs. TVs connect to routers.
Connecting a TV to the network is usually best done through the TV's controls and set up routine. The router rarely does much more than spit out the wifi signal. It is then down to the TV to do its thing.
Where possible, it is usually easier to use a wired connection from the router to the TV. It is easier to set up and less likely to fall over. If you can't run Ethernet cables around the place, you could look into Powerline Ethernet. It turns your mains wiring into an Ethernet circuit.
What are you doing and where does it go wrong?
