J2023
May 31, 2023Aspirant
NETGEAR AC1750 - R6400V2 - MODEM DROPPING OUT WIRED AND WIRELESS
Hi, We have 2 of these modems at 2 addresses same issue. We use them as a BYO modem for our Internet service provider. Internet service provider is certain the fault is not with them or ...
- Jun 01, 2023Thanks for your help, issue RESOLVED- threw the “router” not modem in the e-waste recycling bin and purchased a different brand, which was easy to use and no issues.
michaelkenward
Jun 01, 2023Guru - Experienced User
J2023 wrote:
Hi,
The R6400V2 is a router. No modem involved.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Tried calling Netgear but most unhelpful and only interested in signing up for service contract and different staff offer different pricing/ plans which seems sus to me and no guarantee they can solve my issue or listen.
Be careful with any number you rang after a web search. They may claim to be from Netgear but many are scam, merchants that will try to sell you all sorts of snake oil.
J2023
Jun 01, 2023Aspirant
- michaelkenwardJun 01, 2023Guru - Experienced User
As you are on the NBN network, you should know that it has caused much grief in the router world, especially when people try something like the R6400V2, which has its origins in 2015, when NBN was in its fledgling days.
The people who run NBN have also tweaked the system over the years and have broken quite a few modems and modem/routers in the process.
With luck new hardware will avoid those obsolescence issues.
A good place to look for local help in Oz is:
