J2023
May 31, 2023Aspirant
NETGEAR AC1750 - R6400V2 - MODEM DROPPING OUT WIRED AND WIRELESS
Hi, We have 2 of these modems at 2 addresses same issue. We use them as a BYO modem for our Internet service provider. Internet service provider is certain the fault is not with them or ...
- Jun 01, 2023Thanks for your help, issue RESOLVED- threw the “router” not modem in the e-waste recycling bin and purchased a different brand, which was easy to use and no issues.
J2023
Jun 01, 2023Aspirant
michaelkenward
Jun 01, 2023Guru - Experienced User
As you are on the NBN network, you should know that it has caused much grief in the router world, especially when people try something like the R6400V2, which has its origins in 2015, when NBN was in its fledgling days.
The people who run NBN have also tweaked the system over the years and have broken quite a few modems and modem/routers in the process.
With luck new hardware will avoid those obsolescence issues.
A good place to look for local help in Oz is:
