rwtharp
Nov 21, 2020Follower
Netgear AC1750 (C6300) What is best range extender to use
What is the best range extender to use with my Netgear AC1750 (C6300) WiFi cable modem router that is easy setup and reliable
Nov 21, 2020Guru - Experienced User
The best? one of the triband extenders.
The best for you? unknown. People always ask what the "best" for my device is but then say "my budget is $, thats out of budget".
Basically look at the performance of your router and match an extender to it thats within your budget.
I'd highly recommend the tribands as they perform much better than the dual bands due to their dedicated backhaul. But they do cost more.
