Lyndi
Oct 29, 2020Star
Netgear AC1750 Model R6400 Firmware V1.0.1.62 constantly dropping internet
Internet dropping multiple times per hour, every single day. Sometimes, not typically, the WiFi connection also disconnects. I've been working from home for months now and just dealing with it thin...
- Oct 31, 2020
so step one
modem----PC works and is stable if hardwired? is that correct?
when reinstalling the router follow this guide:
power off modem and router. disconnect coax from modem and all cables from both. I'd recommend factory resetting the router during this step as well (push and hold reset for 7-15 seconds while the router is powered on)
reconnect coax to modem. power it on. give it several minutes.
connect lan cable from modem to wan port on router.
power router on. give it several minutes
then try setup. Make sure the pc is hardwired into the router. That wireless adapter has issues and we're onto step 2. which is hardwiring a device into the router and getting it working. NOT wireless.
Lyndi
Oct 30, 2020Star
Okay... you are right. So... I went back and took the modem all the way down and replugged into the PC, mainly now because the Router won't work at all. I was "attempting" to take it off 5G online to see if that would help, when the internet went down again and whatever change I made, it won't connect at all. Good news, if there's any at the current moment, is that I'm plugged directly from modem into PC and am not having any connectivity issues. I do appreciate your patient reminder!! But unfortunately I've now apparently made matters much worse because the router will not connect to the internet and I can't access the routerlogin admin online because it's telling me that I need to be connected to the Router's wifi... which does not work. Arghhh... Please help me, help myself! :-)
Oct 31, 2020Guru - Experienced User
so step one
- LyndiNov 03, 2020Star
Update....
Resetting the router has fixed the issue. This took more than 1 try as I did not realize I had to hold the paperclip in for 7 seconds, but not a single internet drop since.
Perhaps NetGear should suggest trying this 1st. :womanhappy:
Much thanks for your time and assistance!!
- plemansNov 03, 2020Guru - Experienced User
glad to hear it worked!
