DianeLynne
Aug 03, 2019Tutor
Netgear AC1750 new setup, shows connected, no internet
New set up. Connected to Spectrum modem. Netgear Genie, Macbook Pro, iPad, Iphone, Roku, all show connected, but will not connect to internet. I have unplugged modem, and rebooted. Have unplugged...
- Aug 03, 2019
So here is what I did, and now it’s all working. Unplugged everything.
Plugged modem back in and waited 2-3 minutes, all lights stable. Plugged Nighthawk
in, plugged yellow cable to WAN, to connect with modem. Waited 2-3 minutes
for lights to stabilize.
Only thing I did differently on my 10th attempt to connect, was to NOT plug Roku box in.I went to Netgear genie to verify it was connected. Then I connected each device. IPhones, iPad, MacBook.
After all were connected and verified connected to internet, I plugged Roku in, went to settings, connected Nighthawk. Everything is now working. I don’t know if hooking Roku too soon caused this problem, but it was the only thing I did differently. Thanks for all the help!
DianeLynne
Aug 03, 2019Tutor
I do have an internet connection with old Netgear N600. I set this one up myself. 3rd Netgear device I have set up. The old 2 set up with no problem.
I use the yellow WAN ports.
I do not have any way to open LAN connected devices, only Roku. I don't have the attachement to Macbook Pro to physically connect the Macbook via LAN to Nighthawk.
When I have Nighthawk connected, I can't go to routerlogin.net because I have no internet connection on any device. No devices. All are showing they are connected but in browser typing in ANYTHING, "Safari not connected to the internet".
I am just missing something here. The connection is correct from all the help I have received. All the devices, I can go to wifi, select Netgear60, connect. get 5 bars, good signal. Went to Netgear Genie. Shows both Netgear60, select connect. Shows connected. Then go to Safari, no connection. On Roku, go to settings, select wifi, Netgear60, enter the wifi password, shows connected, 5 bars, good signal. Try to start Netflix, no connection to the internet.
IrvSp
Aug 03, 2019Master
Right, if you try to use the Internet. routerlogin.net goes only to the router. Any device on the LAN with a browser can do that. Anything located on the web without Internet access will of course fail.
Try it and see... just pull the cable to the modem, it will work.
Only thing I can think of with Roku plugged in before connecting to the router could be Roku getting the IP Address that hinders the router? Still, if that were the case it should also fail once the router was up and running? Hard to tell?
