DianeLynne
Aug 03, 2019Tutor
Netgear AC1750 new setup, shows connected, no internet
New set up. Connected to Spectrum modem. Netgear Genie, Macbook Pro, iPad, Iphone, Roku, all show connected, but will not connect to internet. I have unplugged modem, and rebooted. Have unplugged...
- Aug 03, 2019
So here is what I did, and now it’s all working. Unplugged everything.
Plugged modem back in and waited 2-3 minutes, all lights stable. Plugged Nighthawk
in, plugged yellow cable to WAN, to connect with modem. Waited 2-3 minutes
for lights to stabilize.
Only thing I did differently on my 10th attempt to connect, was to NOT plug Roku box in.I went to Netgear genie to verify it was connected. Then I connected each device. IPhones, iPad, MacBook.
After all were connected and verified connected to internet, I plugged Roku in, went to settings, connected Nighthawk. Everything is now working. I don’t know if hooking Roku too soon caused this problem, but it was the only thing I did differently. Thanks for all the help!
DianeLynne
Aug 03, 2019Tutor
michaelkenward
Aug 04, 2019Guru - Experienced User
That was sort of covered earlier on when I said turn on the rest of the network two minutes after the router had completed its stuff.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
But that sounds like it wasn't enough. From your account, simply having the Roku plugged in seems to have been the issue.
So, once again the solution has not much to do with the Netgear router.
Maybe it should be:
- Plug in and turn on computers and rest of network.
