nginfo
Apr 21, 2023Aspirant
Netgear AC1750 (R6400) Has Lots of Lagging Issues
Hi All, My Netgear AC1750 (R6400) Router has all kinds of lagging issues when streaming. I have turned off everything that I think might interfere with data transmission. The receiver is about 35 ...
Apr 21, 2023Guru - Experienced User
What actual speed do you get in that location from the router?
nginfo
I took five measurements from Fast (.com?) and they were 70, 130, 110, 120, 130 Mb/s (I think my units are right, anyway).
I just turned off 2.4 GHz and tested the router running only on 5 GHz, and it lagged and then froze for a good 30s, at which time I reset it. A person was gaming at the same time as I took the measurements and the streaming froze.
- plemansApr 22, 2023Guru - Experienced User
Is it only the one tv?
What modem/gateway is the router connected to?
