LAA2
Dec 18, 2024Follower
Netgear AC1750 WiFi router
Wi-Fi router (model R6400) is successfully set up. I have been using NightHawk App for the past year. Recently, after a network connectivity issue, I can no longer access this App. During the Admin login step, I get an error message that the process has ‘timed out’. I have tried restarting my router many times. I need to access the router settings to determine if a device is having access blocked and to determine which band the device is trying to connect to. How do I find this information if the NightHawk App isn’t available?
1 Reply
- KitsapMaster
LAA2 wrote:Wi-Fi router (model R6400) is successfully set up. I have been using NightHawk App for the past year. Recently, after a network connectivity issue, I can no longer access this App. During the Admin login step, I get an error message that the process has ‘timed out’. I have tried restarting my router many times. I need to access the router settings to determine if a device is having access blocked and to determine which band the device is trying to connect to. How do I find this information if the NightHawk App isn’t available?
Have you tried the web interface via a computer and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Get past the first few sentences where it recommends the mobile application.
