giljay
Nov 08, 2022Follower
Netgear AC1750
When I plug an ethernet cord into any of the 4 ethernet connections, a steady red light comes on for that port. What does the red light mean?
Nov 08, 2022Guru - Experienced User
usually that its connecting at 10/100mbps connection speed.
The manuals are great at going over what specific lights mean. Tough to know with yours as there's multiple models that are AC1750 as its a speed, not a model number.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
