Deanname's avatar
Deanname
Follower
Mar 06, 2022
netgear ac2000 wifi router
I am trying to set up a netgear ac2000 router and have my computer and phones connected fine but my samsung tablets both say connected without internet.  I am not tech savy at all. Can anyone help please. thank you so much
  • FURRYe38's avatar
    AC2000 is a combined WiFi speed.
    What is the model# of the NG router your referring to? R####?
  • plemans's avatar
    What actual model is it?
    What modem/gateway is it connected to?
    What firmware is on it?
    Are you using the default ssid/password that came with the router or did you customize it?
  • michaelkenward's avatar
    michaelkenward
    Deanname wrote:
    ....my samsung tablets both say connected without internet.  I am not tech savy at all. Can anyone help please. thank you so much
    Tell tablets to "Forget network" for the wifi connection to the router. Then set it up afresh.
