Thirsty
Jul 22, 2024Aspirant
Netgear app / R6400v2
My netgear app wil not let me update the latest firmware for my router. Everything else works on the app. I do have an update available. I know I can do it with a computer with an ether cable but hey ...
- Jul 25, 2024
Thirsty wrote:
What do you mean by “ . Just aim the browser at routerlogin.net or the IP address of your router”?This may help.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
Read the bit:
To log in to your NETGEAR router with a web browser
This is best done with a wired LAN connection but wifi also works. The key is to use a web browser rather then an app.
The manual update is safer because there is less risk that the connection will fall over during the firmware download or the update process. If that happens you can end up with broken firmware, which is a pain to repair.
michaelkenward
Jul 23, 2024Guru - Experienced User
What happens when you try to update with the app? That it "doesn't work" isn't much of a clue.
Does the app miss the new version?
Does the app find an update and fail to install it?
I ask because the app is not infallible. Like the on-board check, using the a web browser and the graphical user interface (GUI), these approaches don't always see updates. Heaven only knows why, it is just a fact of life.
It could be because you are trying to make a huge jump from a version that can be a long way behind the latest. Sometimes it could be because the new version has not made it on to the update server.
That is why the manual update is the next option.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You can do this even if you cannot hard wire into the router.
Your mobile device can do it with its browser and a wifi connection rather than the app. Just aim the browser at routerlogin.net or the IP address of your router, usually 192,168.1.1 for the R6400v2.
R6400v2 Firmware Version 1.0.4.128 - NETGEAR Support
The wifi browser isn't the safest router. Wifi can fall over and interrupt the update process, but it usually works.
- ThirstyJul 24, 2024AspirantThanks for your input and suggestions. Yes the App on my phone “nighthawk “ has its latest version. When I select the firmware update check it gives me a “firmware check error” and also says “There was a problem checking firmware update” You are correct that I am 4 updates behind on my router and may be an issue.
What do you mean by “ . Just aim the browser at routerlogin.net or the IP address of your router”? Do you mean my phone really close to the router? Also with a WIFI connection how would that work if I’m connected to my WIFI? Or could I use the internet connection from my car that I have internet connection?- michaelkenwardJul 25, 2024Guru - Experienced User
Read the bit:
- ThirstyJul 28, 2024AspirantJust would like to thank you for your knowledge. I now have the updated version installed in my router. I did use my cell phone and it worked. Thank you
