Thirsty
Jul 22, 2024Aspirant
Netgear app / R6400v2
My netgear app wil not let me update the latest firmware for my router. Everything else works on the app. I do have an update available. I know I can do it with a computer with an ether cable but hey ...
- Jul 25, 2024
Thirsty wrote:
What do you mean by “ . Just aim the browser at routerlogin.net or the IP address of your router”?This may help.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
Read the bit:
To log in to your NETGEAR router with a web browser
This is best done with a wired LAN connection but wifi also works. The key is to use a web browser rather then an app.
The manual update is safer because there is less risk that the connection will fall over during the firmware download or the update process. If that happens you can end up with broken firmware, which is a pain to repair.
Thirsty
Jul 24, 2024Aspirant
Thanks for your input and suggestions. Yes the App on my phone “nighthawk “ has its latest version. When I select the firmware update check it gives me a “firmware check error” and also says “There was a problem checking firmware update” You are correct that I am 4 updates behind on my router and may be an issue.
What do you mean by “ . Just aim the browser at routerlogin.net or the IP address of your router”? Do you mean my phone really close to the router? Also with a WIFI connection how would that work if I’m connected to my WIFI? Or could I use the internet connection from my car that I have internet connection?
michaelkenward
Jul 25, 2024Guru - Experienced User
This may help.
Read the bit:
