jwats13
Jul 30, 2020Aspirant
Netgear C6250 2.4 GHz Extremely Slow and Dropping Signal
My Netgear C6250 I just purchased is only working well/at advertised speeds on the 5GHz band. I have Comcast Xfinity, 300 Mbps. My modem router firmware version is V1.02.01. The issue lies with the 2...
- Jul 31, 2020If your devices have 5ghz, definitely move them to the 5ghz. because its faster and has more channels it suffers from less interference. A great plan.
Jul 31, 2020Guru - Experienced User
The issue is probably the "I live in an apartment complex with a lot of other Wifi signals in range".
2.4ghz is much slower than 5ghz. And its more sensitive to interference because is has less channels available that have overlap. Its made even worse in apartment living because they're so close together.
When I lived in an apartment, my 2.4ghz was pretty much worthless because of the amount of signals.
Did your old device have the same speeds over 2.4ghz.
jwats13
Jul 31, 2020Aspirant
Old device (Xfinity default modem/router) had about the same speeds but was less spotty. Didn't drop the connection nearly as much as my near C6250. Should I just move all of my compatible devices to 5GHz?
- plemansJul 31, 2020Guru - Experienced UserIf your devices have 5ghz, definitely move them to the 5ghz. because its faster and has more channels it suffers from less interference. A great plan.
