jwats13
Jul 30, 2020Aspirant
Netgear C6250 2.4 GHz Extremely Slow and Dropping Signal
My Netgear C6250 I just purchased is only working well/at advertised speeds on the 5GHz band. I have Comcast Xfinity, 300 Mbps. My modem router firmware version is V1.02.01. The issue lies with the 2...
- Jul 31, 2020If your devices have 5ghz, definitely move them to the 5ghz. because its faster and has more channels it suffers from less interference. A great plan.
jwats13
Jul 31, 2020Aspirant
Old device (Xfinity default modem/router) had about the same speeds but was less spotty. Didn't drop the connection nearly as much as my near C6250. Should I just move all of my compatible devices to 5GHz?
Jul 31, 2020Guru - Experienced User
