Jakapi
Oct 12, 2021Follower
Netgear C6300 cant find nat redirect or firewall options
Trying to host game servers and I can't get port forwarding to work. I let it through my firewall, DISABLE my firewall, checked device and public IPs, the thing wont let me use ANY static IPs, I've tried so many options I've even soft bricked it twice and fixed it with factory resets. It's a modem-router so I don't have any other modems or routers hooked up, and my isp doesn't have my IP locked with anything
1 Reply
I fear that "won't work" isn't much to go on.What are you doing and where does it go wrong?
If you can provide a few more details about what you are actually trying to achieve, someone might be able to offer some thoughts.
You might also find it useful to search the community for whatever game server you are trying to set up.
While your question is pretty generic for routers, a modem/.router isn't quite the same thing. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
