PennyBear
May 25, 2021Guide
netgear cable modem cm1000
I have a netgear modem, nighthawk router, and orbi mesh network. Every day I lose internet and have to reset my modem. How do I know if this is a modem problem or something happening with my internet ...
PennyBear
May 27, 2021Guide
I clicked on the icon you said. Attached is what i got.
May 27, 2021Guru - Experienced User
any splitters or signal attenuators in the coax line?
your have a lot of channels not locking.
check the line for damage, kinks, old/bad/cheap/corrorded connectors and replace them if there are.
- PennyBearMay 27, 2021GuideI went and cleared all the wires around it and tightened the connectors and now I have no internet. does this mean it's the cable or is it possible to over tighten the connectors. they seemed loose when I checked them
- PennyBearMay 27, 2021Guideignore last statement I got it working. it just took a minute. we will see if it happens next week but thank you that was very helpful!!
- plemansMay 28, 2021Guru - Experienced User
hope it gave you a better connection back to the isp
