LarryMarks
Dec 16, 2020Follower
Netgear CG3000DV2 Weak Security
WI-FI says I need to configure my router to use WPA2(AES) or WPA3 security type and I dont know how or if it can be done. Help?
Dec 16, 2020Guru - Experienced User
I take it you have an apple device?
they're new ios update is warning everyone of this.
You'd need to upgrade your device to get wpa3. You can change security on your router through your wireless settings portal.
