vero15
Aug 24, 2022Aspirant
NETGEAR CG3100 L WIFI ACTIVATION
Hello, i'm using the NETGEAR box CG3100L , but unfortunately I'm not able to activate the wifi. I press the wifi button for the activation but the led still turned off and I don't know how can I s...
michaelkenward
Aug 24, 2022Guru - Experienced User
I see no sign of that device in the Netgear support system.
There are a few mentions of the CG3100 in the community, but they seem to be about cable modem/routers that Netgear makes, or made about a decade ago, for ISPs. You would do better to ask whoever provided you with this thing.
I press the wifi button for the activation but the led still turned off and I don't know how can I solve this issue.
I don't know what you mean by "activation" for wifi. The wifi buttons on most devices are just on/off switches.
In the case of cable modems, activation is something that happens at the ISP when you connect your modem to the network.
