vero15
Aug 24, 2022Aspirant
NETGEAR CG3100 L WIFI ACTIVATION
Hello, i'm using the NETGEAR box CG3100L , but unfortunately I'm not able to activate the wifi. I press the wifi button for the activation but the led still turned off and I don't know how can I s...
vero15
Hi,
thank you for your answer.
Right now I can connect my laptot at internet only by using the ethernet cable and the wifi doesen't work!
The led the informe you about the wifi status is permanently turn off and even if I press it , it doesent work!
With "wifi activation" I mean the possibilities to connect my pc to the web in a wirless way and not just with the cable!
Aug 24, 2022Guru - Experienced User
Can you see it broadcasting?
can you see it but not connect to it?
Can you connect but it says "connected, no internet"
"doesn't work" isn't very specific.
Did you try factory resetting it and reinstalling it?
Or logging in through the browser to see if the ssid broadcast was disabled?
