vero15
Aug 24, 2022Aspirant
NETGEAR CG3100 L WIFI ACTIVATION
Hello, i'm using the NETGEAR box CG3100L , but unfortunately I'm not able to activate the wifi. I press the wifi button for the activation but the led still turned off and I don't know how can I s...
vero15
I have tried it, but even if I press the button, the wifi's led doesent turn on, so I can't connect my devices to the web by using the wifi, but only with the ethernet cable.
michaelkenward
Aug 24, 2022Guru - Experienced User
Remember, to get on to the wifi, your devices have to be properly set up.
But not knowing anything about this CG3100, which Netgear doesn't support, who knows what is happening at your end?
