Robert4
May 23, 2023Follower
Netgear cm 500 with netgear r6080 router on spectrum 300 mbps only gives 30 mbps
I checked with spectrum they said everything is fine on their end the router ports and router itself are up to date on firmware.paying for 300mbps but only getting 30mbps wifi and hardwired .Please he...
michaelkenward
May 24, 2023Guru - Experienced User
Robert4 wrote:
I checked with spectrum they said everything is fine on their end the router ports and router itself are up to date on firmware.paying for 300mbps but only getting 30mbps wifi and hardwired .Please help
You will never get faster than 100 Mbps with that router.
According to Netgear's manual for the R6080, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.
Your CM500 can deliver 1000 Mbps.
Replace your router with something more capable and you should be able to get nearer to 300 Mbps.
