Zihad
Dec 03, 2023Follower
NETGEAR Dual Band WiFi Router (R6020) how to reset?
How do I perform a factory reset on my NETGEAR router? You can reset your router to its factory settings by pressing and holding the reset button for at least 7 seconds. This will erase all of your se...
michaelkenward
Dec 04, 2023Guru - Experienced User
Link spam.
Reported and best ignored.
