autigers1970
Dec 29, 2020Aspirant
Netgear email says there's a firmware update for my Orbi RBR40 and RBS20, but it doesn't show up
So I got an email about a firmware update from Netgear. I'm on 2.5.1.22 for the RBR40 and 2.5.1.16 for the two RBS20's I have. Checked for an update in the Orbi app and it says I'm up to date. Log...
Dec 29, 2020Guru - Experienced User
It usually must means the update was pushed out to the manual update server first.
You can manually update if you're having issues but if everythings working great, I'd wait on the auto-update to be pushed out.
autigers1970
Jan 02, 2021Aspirant
So, it's been 5 days since I got that email and the auto update function still says "no new firmware available." How long does Netgear generally take between releasing an update before auto-update will see it?
- plemansJan 02, 2021Guru - Experienced User
It varies. There's not set time that I've found
- autigers1970Jan 12, 2021AspirantStill not seeing it in the app. Anyone else having this issue?
- plemansJan 13, 2021Guru - Experienced User
If its bothering you, you can just do the manual update.
