StanleyGF
Dec 05, 2021Aspirant
Netgear Genie Air print won,t connect to printer
Have been using Ntgear Genie on my Dell inspiron laptop for over one year to print from my ios devices.. Have had to reinstall Win 10 two weeks ago. Since then, Genie airprint lets my ios device sel...
StanleyGF
Dec 06, 2021Aspirant
Te Netgear Genie application is downloaded to my windows laptop. This application supplied by Netgear aloows to print to a non airprint printer via any ios device. It used to function prior to the reinstallation of win 10. Now the app allows me to try to print to my printer, the printer is listed in the application main screen and is visible in the ios print menu, but the connection screen shows a message saying the coonection to the printer can't be established.
michaelkenward
Dec 06, 2021Guru - Experienced User
Have you tried reinstalling the app?
I don't use iOS so can't test it.
