29colemanlg's avatar
29colemanlg
Follower
Dec 25, 2018
Netgear genie wireless icon off. How to turn back on.
My wifi has stopped working and my netgear genie wirless icon is off. Internet works fine, how to i turn back on.
  • shadowsports's avatar
    Dec 26, 2018
    There are 2 ways to enable wireless on all 4500 variants.
    Wireless button on the outside of the device.  Or from the router's GUI.  If you want to use custom SSID names, etc, find additional settings under the Set Up Wizard > Wireless in the navigation pane.
