SRoyPC
Jan 06, 2022Aspirant
Netgear JNR1010-100INS 4PT N150 Wireless Router
 Dear Team     On my JNR1010v2, the WiFi disconnects when a new device is connected to the WiFi network. This has been happening since the beginning. This happens both with firmware versions V1.1.0.54...
SRoyPC
Dear plemans
I agree with you. This device has served me since Aug, 2016 and I too feel that it is time for an upgrade.
The device is used at home, and close to 10 devices connect to it on an average.
I would appreciate if you could recommend a suitable replacement. For the record, I have a fibre connection with a static IP.
Thank you.
Jan 06, 2022Guru - Experienced User
If you're on a fibre line, that router is very anemic and bottlenecking you. (unless you pay for really low services speeds).
How big is your home and what's it made of?
There's a ton of options and you can go through and sort/filter by what specs you'd like.
https://www.netgear.com/home/wifi/routers/
You can also check on amazon as I've been seeing a few "renewed" AX netgear routers on there lately if you're looking at going with an AX device.
