t1aden
Jan 28, 2024Aspirant
Netgear limited speeds
So I have 1750ac smart wifi router and it’s supposed to support 1gbps. I have 1gbps internet and it works fine on my other router. I wanted to use this netgear router because of the range but for som...
microchip8
Jan 28, 2024Master
Which router model? AC1750 is a speed, not model! Look at the label
What does this mean "locked at 433mbps"? Is this reported speed or the actual speed you get from testing?
Which wifi band are you using?
Which phone/laptop are you using?
Which modem is in front of the router? Model?
(You will never reach 1 gbps on a phone unless that phone is something better than 2x2 mimo)
