gdk771a's avatar
gdk771a
NETGEAR MBR1515L support for forseeable future?
I was thinking of getting a NETGEAR MBR1515L to provide network access for a security DVR at a remote barn I have that is in a Verizon coverage area.  It appears this router has been around since at least 2012.  I know it will not be supported forever but does anyone know if it will be supported for the next couple of years?  Does Verizon plan to support 4G now that 5G is coming out?  I only need a small amount of data.  The system will email me a picture if it detects movement and I would like to access it remotely to check the logs  I am thinking a monthly 1GB plan will be suffiecient for this type of use.  The main thing is this router has a 4 port hub in it and the DVR I have only has a RJ45 for netwok access.  It does not have WiFi so this router will be perfect for that.
Thanks for any comments or suggestions.
