Mike-1
Aug 27, 2020Aspirant
NETGEAR Model R6080 Internet LED is Red? (Not described in manual)
Firmware Version: V1.0.0.42 Router has Internet LED red and everything works fine. The online PDF manual only documents Internet LED green and off, but not red. Could you please tell me what the r...
- Aug 28, 2020
It usually indicates an issue between the modem and the router. It could be a wire issue, a modem, issue, or potentially even a router issue.
that's why I'd start with the cable.
Mike-1
Manufacturer: Motorola
Model: E31T2V1
Provided by: Spectrum
See here for more info:
https://d15yx0mnc9teae.cloudfront.net/sites/default/files/2020-08/spectrum_d3.1_emta_data_sheet_0.pdf
The real manufacturer of the modem may be Technicolor
Aug 28, 2020Guru - Experienced User
Have you tried changing the ethernet cable between router and modem?
- Mike-1Aug 28, 2020Aspirant
No, everything works fine with the supplied ethernet cable. From time to time the Internet LED turns red, rebooting the router and modem makes the LED turn green again.
Again, what is the meaning of the red Internet LED?
- plemansAug 28, 2020Guru - Experienced User
I presently have no spare cable to swap out for the supplied cable. I do not think that it is the cable since when the Internet LED was red I still had full internet access. Also, I did not touch the cable when I cycled the power strip power switch to reboot the router and modem. So, for now, I will consider the situation resolved (presently the Internet LED is green).
Thanks for your help.
Mike
