Donnamw
Sep 04, 2019Tutor
Netgear Modem/router for ADSL2+ Centurylink
I am currently wanting to buy my own router/modem to avoid rental fee from century link. I am currently using Actiontec PK5001A provided by century link which is fine for internet but my wifi is weak ...
- Sep 06, 2019The k you for all your help
Donnamw
Sep 05, 2019Tutor
Thank you. I will look at ebay and i will also be looking at the links you provided. You have help a lot with my understanding of everything.
michaelkenward
Sep 05, 2019Guru - Experienced User
Your idea of separating modem and router is good.
Many experienced users go down that road for various reasons.
One is that a modem only box can be pretty cheap. Then if you change your Internet service, from DSL to cable for example, you can get rid of the modem and keep whatever router you choose.
Another reason for having a separate router is that Netgear, and maybe other brands, seem to put more effort into providing timely updates for routers. Modem-routers seem to sit at the back of the queue, especially when it comes to adding new features.
- DonnamwSep 05, 2019TutorThank you for replying
- antinodeSep 05, 2019Guru
Unless your ISP uses PPPoA, in which case a simple modem may be too
simple.- DonnamwSep 05, 2019TutorI believe my isp is PPPoe. I am thinking about going with Motorola MD1600 since it’s compatible with my isp and I am having a hard time finding Netgear dsl adsl2+ modems or modem router combos. I will try the Motorola MD1600 then get the Orbi RBK50.
- michaelkenwardSep 06, 2019Guru - Experienced User
Donnamw wrote:
I believe my isp is PPPoe. I am thinking about going with Motorola MD1600 since it’s compatible with my isp and I am having a hard time finding Netgear dsl adsl2+ modems or modem router combos. I will try the Motorola MD1600 then get the Orbi RBK50.If you look at the modems available on Amazon and other places they will often say "Centurylink compatible".
Heaven only knows why anyone would mention the issue if it is not relevant to Centurylink. After all, you did say that was the ISP from the outset.
