krish123
Oct 12, 2016Aspirant
NETGEAR N150 no wireless connection
i have router of netgear. now i connect my internet via ethernet cable but can't connect via wireless .so via wireless i can't connect any device .what should i do?
- Oct 15, 2016
Sounds like its time to get a new router if you've exhausted all troubleshooting options with no change.
ElaineM
Oct 13, 2016NETGEAR Employee Retired
Hello krish123
Welcome to the community!
Kindly see this article to troubleshoot wireless connection.
- wcalifas831Oct 14, 2016Prodigy
Can you tell us the model of the router? Also you might want to power cycle it first and if that doesn't work maybe you can see if there's a firmware update for it that could help resolve the wireless connection issue. Lastly you can do a hard reset by pressing the pinhole on the back for 30 seconds but you'll have to redo the setup. Let us know what happens.
- krish123Oct 14, 2016Aspirant
i Can do all the troubleshoot but can't do anything resoponce from router
- wcalifas831Oct 15, 2016Prodigy
- michaelkenwardOct 17, 2016Guru - Experienced User
Have you been through the setup process described in the Installation Guide?
WNR612v3 | Product | Support | NETGEAR
