krish123
Oct 12, 2016Aspirant
NETGEAR N150 no wireless connection
i have router of netgear. now i connect my internet via ethernet cable but can't connect via wireless .so via wireless i can't connect any device .what should i do?
- Oct 15, 2016
Sounds like its time to get a new router if you've exhausted all troubleshooting options with no change.
krish123
Oct 14, 2016Aspirant
i Can do all the troubleshoot but can't do anything resoponce from router
michaelkenward
Oct 17, 2016Guru - Experienced User
Have you been through the setup process described in the Installation Guide?
WNR612v3 | Product | Support | NETGEAR
